MVP
Anyone update to OS X Mavericks? Any Issues, Problems, Complaints, or Likes?
I'd like to hear feedback. Please Comment.
Sean Rynearson
Re: Anyone update to OS X Mavericks? Any Issues, Problems, Complaints, or Likes?
My VIA 2.0 client crashes on Mavericks.
Already issued a support ticket.
RE-install does not help.
I hope there is an update available :-)
Regards, Harold.
MVP
Thanks for the update! Fill us in if you come to a solution. I will look into it also.!
Thanks again Crazyharold.
Sean Rynearson
Just got a call from the Aruba support team,
They are rebuilding and testing the VIA client for Mavericks.
It should be released around the end of this month.
So until then I have to wait.
No problem, I am happy that they solve it.
Regards, Harold
Contributor I
Anyone have onboarding issues?
I have observed and am getting complaints that our captive portal does not work on OS X Mavericks.   Anyone know why?
I got a problem at onboarding. I was clean installation as Mavericks(OSX 10.9) and tried to onboarding.
I got a error message like this "NSCocoaErrorDomain:3840"
Frequent Contributor I
we have issues onboarding as well it says cannot install profile and some error msg...
we were able to use a mac that had been upgraded to 10.9 for both Onboard and Onguard. When we tried a fresh install we were unable to get past device enrollment,
thanks for submitting.  I was about to do it.
