Occasional Contributor I
Ap-rename help
I provisioned ap105s using the certificate. Later I tried to use the ap-rename cli command, the name did not change.  I reprovisioned the same ap using a PAP username and password and the ap re-name command command worked.  Has anyone noticed this ?
6000 Controller
Version 6.1.3.0
Re: Ap-rename help
Aruba TAC worked through the problem and the solution is posted below. I must be the only one to have this problem.
(Aruba) #local-userdb-ap modify mac-address d8:c7:c8:ce:c9:b1 ap-name Name2013
