I have 3x105 APs that I am trying to get working over an MPLS network. My Aruba 620 controller is sitting in a datacentre and the 3 APs are located at 3 different sites.
I could not get the APs to work with DHCP or DNS however all other systems at the site work fine. I ended up setting up static details in the APs and connected them directly to the controllers. The APs downloaded the initial image and booted up fine with the Radios coming online. I set the APs up using the RAPs using the wizards on the controller.
I then changed the IPs and move the APs to the remote sites. Once in place the boot up and on the controller I can see the APs as active (The IP is also updated) . However the radios never come up and eventually the APs reboot.
Could someone give me some advice on where my configuration may have gone wrong? I have not been able to find a log that has any pertinent information in it.
Chris
