Super Contributor I
AppRF
Hi Team.
Need to be activated FIREWALL ENFORCEMENT license to use APPRF?
The serie controller is 7000
Thanks!
Re: AppRF
Yes, PEFNG is required.
Tim Cappalli | Aruba Security
Super Contributor I
Re: AppRF
Hi cappalli
What would be the difference with Cisco? I have understood that it is not necessary for additional Cisco licensing
Re: AppRF
Cisco controllers do not have a stateful firewall and can't do deep packet inspection.
Super Contributor I
Re: AppRF
Thanks Tim,
