AppleTV not working across VLANs
HI All,
I have AOS 6.1.3.4 AirGroup running in a lab to test out the lovely AirGroup features.
As expected mirroring, photos etc are working when the iPad and AppleTV are connected to the same SSID.
However when they're connected to different SSIDs which are on different VLANs it's not working. The iPad can see the AppleTV and attempt to mirror or show photos but doesn't show.
AppleTV and iPad are fully updated and both are connected to a different PSK auth SSIDs.
I've enabled airgroup and allowall services..
AirGroup Feature
Status
Enabled
AirGroup Enforce Registration
Status
Disabled
AirGroup Service Information
Service Status
airplay Enabled
airprint Enabled
allowall Enabled
I've enabled ipv6 on the stateful firewall as per another post.
Here are the VAPs that the devices are connected to.
(Aruba3200) #show wlan virtual-ap iPad-vap_prof
Virtual AP profile "iPad-vap_prof"
Parameter Value
Virtual AP enable Enabled
Allowed band all
AAA Profile iPad-aaa_prof
802.11K Profile default
SSID Profile iPad-ssid_prof
VLAN 250
Forward mode tunnel
Deny time range N/A
Mobile IP Enabled
HA Discovery on-association Disabled
DoS Prevention Disabled
Station Blacklisting Disabled
Blacklist Time 3600 sec
Dynamic Multicast Optimization (DMO) Disabled
Dynamic Multicast Optimization (DMO) Threshold 6
Authentication Failure Blacklist Time 3600 sec
Strict Compliance Disabled
VLAN Mobility Disabled
Preserve Client VLAN Disabled
Remote-AP Operation standard
Drop Broadcast and Multicast Enabled
Convert Broadcast ARP requests to unicast Enabled
Deny inter user traffic Disabled
Band Steering Disabled
Steering Mode prefer-5ghz
WMM Traffic Management Profile N/A
(Aruba3200) #show wlan virtual-ap AppleTV-vap_prof
Virtual AP profile "AppleTV-vap_prof"
Parameter Value
Allowed band all
AAA Profile AppleTV-aaa_prof
SSID Profile AppleTV-ssid_prof
VLAN 2
Forward mode tunnel
Deny time range N/A
Mobile IP Enabled
Anyone got any ideas?
James
Cheers
James
Re: AppleTV not working across VLANs
Please make sure you do not have NAT or IP Nat Inside or Source NAT on any of those VLANs.  Bonjour does not work with NAT.
BONJOUR!!!
That's working now. Thanks Colin.
Cheers
James
Awesome!
I wish everything else was that easy...
Frequent Contributor II
