Aps wont sync with controller
Hi guys I just recently started having another problem with my controller. It says I have 30 licenses and that 25 are used and I have 5 available, Also it says I have 30 PEFs and 25 are being used. However when I try and set up a new AP, it will not grab an image from the controller and it will not sync up to the server as available for provision. Can someone point me in the right direction as where to start diagnosing?
Re: Aps wont sync with controller
RESOLVED****
Apparenty our new 1080p 180degree camera install was basically DDOSing our switch and not letting the ap get out. It is working now with the camera offline, thanks.
Just had a similar issue.....
Make sure your DNS is handing out :   aruba-master    and pointing the IP address at the master controller....
Grant
Thank you, that could have been contributing to the issue also as it was not added.
