Frequent Contributor I
Are hybrid APs supported on 7005 controller?
I'm configuring a 7005 controller AP radio profile and I'm not seeing the "spectrum monitoring" checkbox under g or a.  Is this not supported on the 7005, or do I need to enable something else to get it?
Thanks!
Re: Are hybrid APs supported on 7005 controller?
Do you have the rf protect license installed? Spectrum requires this.
Thanks!  I should have known, but I'm coming from an older implementation.
