Occasional Contributor I
Ariwave Report definition question.
Hi Community.
Whats is exactly that "AOS Device Type Summary" do in an Airwave Report?
Thank you
Re: Ariwave Report definition question.
It gives you a report of the Device Type as seen by the controller.
For example, "Win XP" "Mac OS" "Chromecast" etc
Tim Cappalli | Aruba Security
