Aruba 105 Ap and PC-w3400 on differefnt subnets
  • 1.  Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 11:59 AM
    Hi everyone,
    I am pretty new to this and I really appereciate if anyone can help me on this.
    I have a powerconnect-w3400 on site 1 and couple of aruba 105s on my site 2, on different subnets. I want my APs to see the controller on site one. and I also have a local DHCP server on site 2.
    could anyone tell me what whould be the best to do to connect APs to controller?
    Yasaman
  • 2.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 12:11 PM
    There are 3 ways in which an AP discovers the controller
    1. DHCP - option 43
    2. ADP - requires layer2 connectivity
    3. DNS query for "aruba-master"
    Since, the AP and controller are not on the same VLAN, you can use option1 or option3 for the APs to discover the master controller IP address.
    Option1: You need to configure the Option 43 on the DHCP server to the controller IP address
    Option3: You need to configure an A record on your DNS server for "aruba-master" that resolves to the controller IP address
    Hope it helps.
  • 3.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 12:14 PM
    Thank you so much for your answer,
    Can you tell me how am i going to do these, first for DHCP option43, what whould be the vendor class ID and the sub_option code and is the IP the IP of my controller? Can you please tell me a step by step on how to do option 43 and what needs to be done on my controller and Ap?
    and as for DNS, i just need to creat that record and I am good to go?
    Thanks again
  • 4.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 12:16 PM
    Yes. you just need to create a DNS entry for "aruba-master" and you are good to go. In that case you do not need to configure option 43 on your DHCP server.
  • 5.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 12:18 PM
    Thank you, Could you just let me know the steps fro option 43 just in case?
    Thanks :smileyhappy:
  • 6.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 12:19 PM
    and is Powerconnect-w3400 the Arube master? do i have to do anything on it or on APs?
  • 7.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 01:36 PM
    Here is a cheatsheet  on option 43
    Option 60 == ArubaAP
    Option 43 == x.x.x.x
    Where x.x.x.x == IP address of the master controller
    JF
  • 8.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 01:37 PM
    You can designate one of the controllers as the 'master' and all APs will boot up to that controller and get their profile information from that controller.
  • 9.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 02:25 PM
    Thank you, how can i designate the controller to be master?
  • 10.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 02:33 PM
    How many controllers do you have in your network?
    By default, all controllers come up as a standalone master controller.
    It would be very useful to read the campus VRD to understand the working of Aruba controllers and APs.
    http://www.arubanetworks.com/technology/reference-design-guides/#Campus
  • 11.  RE: Aruba 105 Ap and PC-w3400 on differefnt subnets
    Posted Aug 14, 2012 02:54 PM
    Thanks everyone.
