Aruba 200 Mobility Controller and 105 APS
Hi Guys,
new to the Aruba gear. I am changing networks for the Aruba gear. from 192.168.1.x to 192.168.2.x. I can see where to change the mobility controller ip, but how do i do this for the APs
Ideally we'd want the ap's on dhcp and relaying dhcp.
Re: Aruba 200 Mobility Controller and 105 APS
What is supplying DHCP for the APs now?  That is what you change.
I think its another router. But I cannot confirm. It might not be. I'm locked out of this router. If it's been statically set, what do I do?
To be clear, you want to change the ip address that APs get?  If yes, that would be changed on whatever device is supplying DHCP now.
Sure, but if the APs have a static ip address assigned through the mobility controller, how do I change this? From what I can see I need to click on provision?
To change the mobility controller I believe I just have to change the IP and Subnet mask in the vlan section and add new static route for the new gateway, correct?
Sorry for the stupid questions. I think I'll do a course in this soon.
If the APs are up, you can go to configuration> Wireless> AP installation.  Click on your AP and then click on provision.  Yes.
