Aruba 205 APs
What is thew max output for a 205 WAP.  We are trying to determine if we need a 360 or a 900 Watt power supply for our Alcatel 6850 switch.
Aruba
Re: Aruba 205 APs
802.3af power should supply sufficent power to fully power an AP-205.   I believe the number is up to 12.5 watts per AP-205.
AMFX | ACCX | ACDX | ACMX
Aruba
Re: Aruba 205 APs
From the AP-200 series datasheet (attached):
