Occasional Contributor I
Aruba 225 LED Status
Morning,
I was looking for some information on the meaning of the LED's on a 225 AC Access Point.
I have seen some that are flashing green and some that go orange. Curious as to exactly what they all mean. Also can you let me know how I can check if an Access Point is broadcasting at AC or not.
Thanks.
Re: Aruba 225 LED Status
Here are the different LED status meanings:
You can run show ap bss-table ap-name <ap-name> and look for a-VHT for the phy.
Tim Cappalli | Aruba Security
show ap active
Using VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
Active AP Table
Name         Group          IP Address    11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  Uptime  Outer IP
home-225-ap  HOME-AP-GROUP  172.16.20.10  0            AP:HT:1/21/21        0            AP:VHT:36E/21/21     225      Ada    1m:9s   N/A
(HOME-MASTER-CONTROLLER) #show  ap bss-table
fm (forward mode): T-Tunnel, S-Split, D-Decrypt Tunnel, B-Bridge (s-standard, p-persistent, b-backup, a-always)
Aruba AP BSS Table
bss                ess          port  ip            phy    type  ch/EIRP/max-EIRP  cur-cl  ap name      in-t(s)  tot-t   mtu   acl-state  acl  fm
6c:f3:7f:e7:59:b0  home_secure  N/A   172.16.20.10  a-VHT  ap    36E/21/21         0       home-225-ap  0        3m:24s  1500  -          59   T
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you to both of you.
I understand that VHT (Very High Throughput) means AC, unless I am mistaken. Meaning since my APs are reporting that in their status section they are pushing out AC Wireless.
I was not sure as despite having PWR, ETH, 2.4GHz & 5.0GHz all green an Engineer told me that without a POE+ Injector I would not get full AC Wireless.
I believe I figure it out that a POE switch can't power multiple AC AP's, however a single POE Injector can power just 1 AP.
If you are on the latest code, 6.3.1.x., af power can be used for VHT on the 225.
Contributor I
is there a command in the controller cli that will allow us to see the power status of these APs? if they are full or in power save mode?
Thanks!
show ap debug system-status ap-name <ap-name> | begin "Power Status"
Contributor II
Lots of info here, thank you all.
We recently changed all APs to 225 and ran to the same "issue".
However we were wondering if somehow we can force all AP to be in full mode (not POE power saving)
This is just an estetic issue on our case because the red light is disturbing the clients.
Thank you.
I'm actually having the same problem with the new 325.  I can't seem to force it to use AT power.  Wondering if it is on the Cisco side as well.  I know this is old, but any solution?
What switch is this and what is your configuration on the switch side?
