Aruba 2400 Controller and AP-93
I am new to Aruba products and wireless networking...... I am trying to connect 2 AP-93 on our controller which is a 2400 Aruba OS 5.0.1 and has about 15 AP-61 connected already. The problem is I cannot apply a provisional profile and not even change the AP-93 name. Do I need to do an upgrade on our controller?
Thank you in advance
Re: Aruba 2400 Controller and AP-93
Hi Lefko77 - The AP93 needs a minimum of 5.0.4.2 on the controller.  5.0.4.5 is the latest, so you'd want to go with that.
I appreciate the response I will try to upgrade the firmware.
