Aruba 2530 reset button won't work
When I fisrt connected the switch with putty  on COM port, the switch successfully booted once and then it has frozen.
Not when I boot the switch the Locator LED and the Dual-Personnality Ports LEDs are blinking on a 2 seconds interval.
I've tried to do a factory reset by pressing the Reset button with the Clear button but nothing happens. When I connect the COM port, nothing happens too.
Any ideas?
Re: Aruba 2530 reset button won't work
Yes me too, anyone can help?
