Occasional Contributor I
Aruba 275 A/C power
Does anyone know what part number I can use for the A/C power adaptor for the Aruba 275? I found the weatherproof cable part number but not the actual A/C adaptor part number. It is the same as the Aruba 325 - JX990A?
Re: Aruba 275 A/C power
AP-275 power cable is not the same for indoor APs.
http://www.arubanetworks.com/assets/og/OG_AP-270Series.pdf
If you need an AC power cable for US, use
JW081A PC-OD-AC-P-NA MST2HAC and AP-27x Weatherized AC Power 5m North Amer Cable
Jerrod Howard
Thanks, I did see the power cable in this document but I'm actually looking for the power brick part number. I read the ordering guide and see plenty of POE adapters but no A/C power brick.
There's no AC power brick for th 275, just the AC cable straight into the AP.
Jerrod Howard
Oh, I see! I looked up an image of the power cable and it does makes sense :) Thank you very much...that's great to know.
