Aruba 2930 F Firmware 16.03 and qos Whatch-queue
With This config:
class ipv4 "remarcadscp"
10 match ip
policy qos "marcadscp"
10 class ipv4 "remarcadscp" action dscp cs7
interface 10
service-policy "marcadscp" in
I can,t see Drops related with Eg Rate-limit.
With qos whatch-queue Command. Related with Procurve OS it,s OK the results but, doesn,t exist with aruba OS:
When QoS is used to prioritize traffic, different kinds of traffic can be assigned to different egress queues. If there is a great deal of traffic, it is desirable to be able determine if some traffic to the lower priority queues was dropped. This feature allows the egress queues for one port to be monitored for dropped packets.
[no] qos watch-queue port out
Configures the switch to start monitoring the specified port for the dropped packets for each queue. Disabling and then re-enabling monitoring on a port clears the per-queue dropped packet counters. For example:
HP Switch(config)#: qos watch-queue 5 out
The no form of the command stops the collection of dropped traffic information. (Default: disabled)
Does exist any command related with this topic in order to see Dropped Packets in for example Rate limit?¿
