Aruba 3200 Wireless Giving out address from wrong VLAN
  • 1.  Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 01:40 PM
    Hey all,
    I have an SSID that is attached to vlan 40 however when a user tries to connect to it, the connection takes a while and says "limited access" and when it finally does get an IP its either from a different vlan range or a self assigned IP.
    Any ideas?
    #3200
  • 2.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 01:59 PM
    Give us some more relevant info:
    • What encryption are u using? Are u using any auth (like 802.1x or mac-auth?)
    • Check the user-role that your client getting.
    • Check that u got connectivity to VLAN40 , and that it's UP
    • DHCP from external server or from the controller?
    • If u setting another VLAN - is the client getting an IP , and it able to connect?
  • 3.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 02:29 PM
    Are you using tunnel or bridge forward mode?
    Can you post any relevant config? (ssid-profile, virtual-ap profile, aaa profile, etc)
    What version are you running?
    If you are on ArubaOS 6.3 you can use the packet-capture feature on the controller via the CLI:
    packet-capture destination local-filesystem
    packet-capture datapath wifi-client <MAC ADDR>
    Then pull the PCAP from the logs.tar.
  • 4.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:05 PM
    Okay well here is my how I want my SSID to run.
    2 layers on authentication.
    1) WPA-2 Personal
    2) MAC Auth
    I am currently testing with a computer that I inputted the MAC address into the Internal DB already.
    AP profile: VLAN 40, Forward Mode: Tunnel, allowed band: all
    AAA Profile: I have a Mac Auth profile configured, MAC Auth server group, and those were previously working.
    When the user first connects, if they are not in the Internal DB they are to get a "denyall" role but if they do auth then they can get access to certain spots in the network.
    The issue is that I cannot even connect to the network and get a valid IP address from the DHCP server. (With or without the "Enforce DHCP" option.)
  • 5.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:16 PM
    USE logon as initial role and try connect your client.
    (if it's allowed mac it's should get the role u configured ,if it's allowed mac and it's getting web-auth disabled web page - u got something missconfigured in your mac-auth profile/mac-auth list.)
    or make a role with only DHCP allowed.
    I think the deny all is causing it for u right now.
  • 6.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:20 PM
  • 7.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:26 PM
    I am using a guest role as initial however its still not working.
    AND
    That link you provided was a link I posted, as you can tell it was working but for some reason is no longer giving out DHCP.
  • 8.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:34 PM
    This is the output of the Show association command
    Association Table
    BSSID: xx:xx:xx:xx:xx
    MAC: xx:xx:xx:xx:xx:xx
    Assoc: y
    auth: y
    aid: 1
    I-int: 10
    essid: Dev
    vlan-id: 40 (So it is associating with Vlan 40 but not getting an address from dhcp?)
    assoc time: 5s (I just tried to connect it) ...
    Parameter Value
    Channel 161
    Channel Frame Retry Rate(%) 13
    Channel Frame Low Speed Rate(%) 0
    Channel Frame Non Unicast Rate(%) 10
    Channel Frame Fragmentation Rate(%) 25
    Channel Frame Error Rate(%) 10
    Channel Bandwidth Rate(kbps) 315
    Channel Noise 91
    Client Frame Retry Rate(%) 0
    Client Frame Low Speed Rate(%) 0
    Client Frame Non Unicast Rate(%) 0
    Client Frame Fragmentation Rate(%) 0
    Client Frame Receive Error Rate(%) 0
    Client Bandwidth Rate(kbps) 0
    Client Tx Packets 0
    Client Rx Packets 0
    Client Tx Bytes 0
    Client Rx Bytes 0
    Client SNR 0
  • 9.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:41 PM
    u sure vlan40 working like needed and connected like need to your controller?
  • 10.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:44 PM
    If you are doing DHCP on the controller:
    - Do you have an IP on "interface vlan 40"?
    - Do you have the DHCP server enabled?
    - Do you have a DHCP scope for this subnet?
  • 11.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:45 PM
    Does the DHCP server is on the controller? or an External one? (for vlan40)
    and on what ArubaOS are?
  • 12.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:59 PM
    Is VLAN 40 Trusted on the trunk back to the uplink ?
  • 13.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 05, 2014 04:12 PM
    Hey guys,
    Thanks to everyone who replied, it seems there was some issue with the firewall policies but I couldn't delete it for some reason one of the rules would not delete. I had to re-write the policies and it works.
  • 14.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 03:27 PM
    Even if I remove MAC authentication and just leave Wpa2-personal it still does the same thing.
    JD
  • 15.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 02:55 PM
    Encryption: 802.1x - Connecting takes a long time (Notification comes up saying that its taking longer than usual, and then I have limited connectivity)
    User-Role: Aruba Controller isn't even finding the user as they are getting a self assigned IP (169.x.x.x)
    VLAN 40 is up and I can ping the IP I set to it.
    DHCP from the controller.
    UPDATE: I saw it get an address from the correct pool for about 2 mintues then it reverted back to the 169.x.x.x address.
  • 16.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 04, 2014 02:54 PM
    Please share the following :
    show ap association client-mac <device mac>
    show user mac <device mac>
    show rights <role name>
    Is your uplink hosting that VLAN ? or your controller ?
    Do you have enforce-dhcp enabled under the aaa profile ?
  • 17.  RE: Aruba 3200 Wireless Giving out address from wrong VLAN
    Posted Feb 05, 2014 04:20 PM
    Thanks for the update. Glad you solved it.
    Have a great week.
