Contributor I
Aruba 3200 drops clients
I have a mobility controller 3200, and four ap 125s.
I also have a cisco aironet 3600 (just one, no controller)
When clients are on the aruba gear, they routinely get booted off the wireless network, but absolutely never from the cisco, and I can't for the life of me figure out why.
I'm not good enough with the aruba equipment to really be successful in figuring out how to troubleshoot this either.
is there a way to 'watch' a specific mac address and find every log associated with it to sort out why it's dropping off the network?
I'm running AirOS 6.4.4.9, by the way - its the latest version of AirOS that I think this controller will run.
Re: Aruba 3200 drops clients
Do you have "Drop Broadcast and Unknown Multicast" enabled on all of your Virtual APS?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
Nope!
Contributor II
A good point to start can be to debug a specific user. You can enable debug for a specific user with below command:
(Jibran-TEST) (config) #logging level debugging user-debug <mac>
Jibran Aziz
ACDX | ACCP | ACMP | ACMA | CCIE (RnS, SP, DC) | JNCIS | JNCIA
Viss wrote:
Nope!
Okay.  Please do that and retest.
Contributor I
Apologies for the delay.
Turning on the dropping of unknown multicast didn't change the behavior at all.
Please PM me your email address so I can send you a link for your tech support..
