Aruba 3200XM Controller
  • 1.  Aruba 3200XM Controller
    Posted Oct 29, 2013 09:50 AM
    How many CAPs Aruba 3200XM can support. As per my understanding Aruba 3200 support 32 CAPs.  Will this limit increased in XM model? Please clarify
    #3200
  • 2.  RE: Aruba 3200XM Controller
    Posted Oct 29, 2013 09:52 AM
    The XM model will not increase capacity. The extra memory is needed to support the newer AOS code which has gotten larger as features are added.
  • 3.  RE: Aruba 3200XM Controller
    Posted Oct 29, 2013 09:58 AM
    Thanks Cappalli,
    I conveyed the same to the customer, but than he ask to provide any document from Aruba which shows that XM only support 32 CAP's. I tried to find on website but there is data sheet showing capabilities of 3200 series controller not 3200XM controller. I shall be thankful to you if you can provide me the such document.
    My customer was saying 3200XM can support 128 RAPs or 128 CAP'. But as per my understanding 3200XM can support either 32 CAPS or 128 RAP's
  • 4.  RE: Aruba 3200XM Controller
    Posted Oct 29, 2013 10:00 AM
  • 5.  RE: Aruba 3200XM Controller
    Posted Oct 29, 2013 10:15 AM
    Thank you so much
