Frequent Contributor II
Aruba 3400 Controller OS Jump
I have a 3400 controller running 5.0.2.1, can I jump directly to 6.1.3.8 with out issue?
Brandon
Re: Aruba 3400 Controller OS Jump
You should upgrade to 5.0.4.9 prior to upgrading to 6.1.3.8.
If you have RAPs, make sure you read page 13 (82) of the release notes (attached).
Tim Cappalli | Aruba Security
Occasional Contributor I
Thanks for the quick response.  Would you recommend putting a different OS on the controller?  Say 6.2.1.3?
6.2.1.3 came out today so I personally can't recommend it yet, but 6.2.1.2
was very stable.
Do you need AirGroup functionality? 6.3 has been out for a few weeks as
well. It has ClientMatch, which is part of the next generation of ARM.
Sent from my BlackBerry Z10
Thanks for the info on the RAP's, might have missed that one on my upgrade.
6.3.0.1 also came out today
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
