Occasional Contributor I
Aruba 3400 controller as Master and 7005 as Local, Is it compatible ?
Aruba 3400 controller as "master" and 7005 controller as "local" ?
Re: Aruba 3400 controller as Master and 7005 as Local, Is it compatible ?
It should not be a problem if they both are on the same level of ArubaOS software.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks for your prompt reply.
