- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
05-28-2017 01:34 AM
We have a 3400 controller with 52 access points. We are in the process of extending our wifi and it means adding 25 more access points. Can our 3400 controller handle this? please advice.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Aruba 3400 controller
05-28-2017 03:11 AM
The 3400 controller can only handle 64 access points, unfortunately..
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-28-2017 07:21 AM
10 ap to it?
Sent from iPhone
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-28-2017 07:46 AM - edited 05-28-2017 07:52 AM
The only option to run a Virtual Controller is on ArubaOS 8.1 and above. The 3400 is only supported to ArubaOS 6.x. The recommended replacement for the 3400 is the 7030: http://www.arubanetworks.com/assets/support/EOS_Notice_3000_Series_Controllers.pdf which supports ArubaOS 6.x and 8.x.
EDIT. You should be looking at the 7205 controller, instead: http://www.arubanetworks.com/assets/ds/DS_7200Series.pdf
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
