Frequent Contributor I
Aruba 500 Controller OS Upgrade
If we upgrade our controller OS from an older 5.0 OS to the latest 5.X OS, do we lose our configurations? Such as IP address, AP profiles, keys, licenses etc.? I already created a tar.gz backup of the controller files and copied it to our TFTP server. Thanks.
Aruba
Re: Aruba 500 Controller OS Upgrade
You will not lose configuration during an upgrade.
That being said, your backup prior to upgrade is a standard "Best practice" for any network/server/IT device, so great work!   Doesn't hurt to have the comfort of a backup sitting off-device/off-site right?
JF
