Frequent Contributor II
Aruba 6000 Controller .11ac
As far as i know Aruba 6000 Controller with M3 Modules supports .11ac AP
However , Customer asked does it sully support it ? Any limitations ?
For example can we have all APs as .11ac AP ?
Re: Aruba 6000 Controller .11ac
Yes, fully supported.
Tim Cappalli | Aruba Security
No limitation from 802.11ac perspective , the M3 is fully capable to support 802.11ac APs
Thank you
Victor Fabian
Lead Mobility Architect @WEI
