Aruba 620 -AP-93 Extreme slow wifi
I am running a latest firmware 620 wifi controller wich has multiple AP-93
My wifi is super slow. When I use direct cable I can download @ 7000kb per sec. When I use the wifi I get 600-1000KB per sec for the same
download. I have tried multiple NIC's with the same result. Also my other laptops have the same problem.
Currently using an AC-7260. Can someone help me to troubleshoot? I am 2 metres away from the accespoint. There are no other SSID's in the neighboorhood
Re: Aruba 620 -AP-93 Extreme slow wifi
Are u using 20Mhz wide in 2.4 ? or 40Mhz wide in 5.0?
(Your 2.4Ghz enviroment - may causing some issues)
Please try to use only 5.0Ghz with 40Mz...and let us know the results.
If you've not done so already, upgrade the 7260 to the latest driver.
The other wireless NICs you've tried, are they 7260 as well?
ACCP, ACCX #817, ACMP, ACMX #294
Have you check if there is a lot of noise in the 2.4ghz band which could be consuming all your airtime?
Please check on the dashboard on the noise and channel busy %
You will see slow wifi if thats the case.
Alternetworks Corp
