Occasional Contributor I
Aruba 620 Wireless Network Capability
Hello
We have an Aruba 620 with AP105 access points. Can the 620 accommodate three separate wireless networks?
Re: Aruba 620 Wireless Network Capability
Yes, it can.
Thansk cjoseph.
Just out of curiosity, how many does it support?
I do not know but it is quite a few.
Is there anywhere I could find out? I've looked through various literature / features lists, but cannot find anything.
The AP-104/105 supports up to 8 BSSIDs per radio. Best practice is 2 (one
for each encryption type)
Tim Cappalli | Aruba Security
Instead me trying to find a number that may not be written down, what are you trying to do?
Thanks.
When you say best practice, if we were to add one more - what are the disadvantages?
Just more airtime consumption with more management frames.
OK, that makes sense. Thanks.
