Is there a way to escape the initial configuration dialog? I am writing some scripts for the Aruba 650 controller. From a cleared configuration is there any method for to escape from the configuration dialog? The best I could come up with is to cut and paste the following:
master
172.16.0.254
255.255.255.0
none
yes
EST-5:0
00:00:00
1/10/2013
password
password
password
password
no
yes
Then when it controller comes back up, then I have to reset the management vlan to 200, then reload again, then run the rest of the scipt to configure the ports and other items.
Is there a better way? How do people deploy these devices quickly? I am pretty new to the platform and have a deployment project. Deployments are cookie cutter with the exception of IP Space. Using the FIPS image. Already been locked out a few times playing with configuration backups. I am looking for the most efficient way to get these out of the box configured and ready for deployment. I am not sure that there really is a correct answer other than you can by the dialog or not. Mostly looking for information on how to deploy efficiently. Thanks.
Douglas
