Aruba 650 Upgrade problems
I was running 6.1.2.0 on an Aruba 650.  I tried upgrading to the latest 6.1.3.4 and ran into a space issue.  I tried reverting back to 6.0.1.3 and 6.0.0.0. These were loaded via "CPBOOT". I was thinking it had to do with the repartition during the upgrade, however that was not the case.  It appears that something is eating up all the space in /flash. I deleted everything I could but it looks like there is something hidden. While in CPBOOT I ran a FLTEST and recieved this error Error: start and/or end address not on sector boundary.   How do I fix this problem since there is no format flash or any other fsck command?
(Aruba650) #show ver
ArubaOS (MODEL: Aruba650-US), Version 6.0.0.0
Website: http://www.arubanetworks.com
Copyright (c) 2002-2010, Aruba Networks, Inc.
Compiled on 2010-10-27 at 21:34:32 PDT (build 25864) by p4build
ROM: System Bootstrap, Version CPBoot 1.0.0.0 (build 23274)
Built: 2010-01-19 11:11:41
Built by: p4build@re_client_23274
Switch uptime is 18 minutes 29 seconds
Reboot Cause: Power Failure.
Supervisor Card
Processor XLS 408 (revision B1) with 891M bytes of memory.
32K bytes of non-volatile configuration memory.
256M bytes of Supervisor Card System flash (model=NAND 256MB).
(Aruba650) #show storage
Filesystem                Size      Used Available Use% Mounted on
none                    300.0M      1.5M    298.5M   1% /tmp
/dev/mtdblock11         156.0M    130.3M     25.7M  84% /flash
/dev/mtdblock9           50.0M     47.0M      3.0M  94% /mnt/img0
/dev/mtdblock10          50.0M     46.7M      3.3M  93% /mnt/img1
(Aruba650) #dir
-rw-r--r--    1 root     root         8248 Oct  6 23:03 default.cfg
drwxr-xr-x    3 root     root            0 Oct  6 23:11 fieldCerts
-rw-r--r--    1 root     root          412 Mar 11  2012 lic.txt
drwx------    2 root     root            0 Oct  6 23:02 tpm
cpboot> fltest
expected: 0, read: e000e000
expected: 1, read: e000e000
expected: 2, read: e000e000
expected: 3, read: e000e000
expected: 4, read: e000e000
expected: 5, read: e000e000
expected: 6, read: e000e000
expected: 7, read: e000e000
expected: 8, read: e000e000
expected: 9, read: e000e000
expected: a, read: e000e000
expected: b, read: e000e000
expected: c, read: e000e000
expected: d, read: e000e000
expected: e, read: e000e000
expected: f, read: e000e000
expected: 10, read: e000e000
expected: 11, read: e000e000
expected: 12, read: e000e000
expected: 13, read: e000e000
