Aruba 650 controller dst-nat and proxy arp.
I've created an ACL to my internet facing VLAN and configured a DST-NAT rule to allow RDP to an inside host.
This is working just fine when I use  "localip" as destination, but I would like to use another IP on the WAN-subnet for this kind of traffic. But I can't get the WLC to respond to the traffic. I believe this is an issue with proxy ARP.
ip access-list session ACL_WAN
  any   alias localip tcp 3389  dst-nat ip 10.103.10.23 3389 log
Re: Aruba 650 controller dst-nat and proxy arp.
AFAIK, you can only do this for an ip address that exists on the controller.
Just what I was worried about...
Do you have a tip for a work around or something?
I do not have a workaround, but you can enter this as a suggestion on the Ideas Portal here:  https://arubanetworkskb.secure.force.com/cp/ideas/ideaList.apexp
