Contributor I
Aruba 7005 controller showing access points poor quality in dashboard
Hi
I have got a customer that has a 7005 controller with 5 x AP225 aggregrated on both Ethernet ports using GRE stripping.  Everything is working OK but it is showing access points with poor quality in dashboard.
Could this be an issue with the power settings?  The AP's are fairly close to each other.
I have attached a screen shot.
Any help welcome.
David
Valued Contributor II
Re: Aruba 7005 controller showing access points poor quality in dashboard
Hi Friend,
The output is showing Poor Quality for only one AP. it may be due to non WiFI devices because for the same AP, 5Ghz band is very good so please ensure that there are no non WiFi device such as , Microwave oven, Bluetooth devices etc.. close to that AP ( Streets-AP-WPA4)
Please feel free for any further query on this.
Cheers,
Venu Puduchery,
