Aruba 7010 master and local issue with AP HA availability
  • 1.  Aruba 7010 master and local issue with AP HA availability
    Posted Dec 01, 2016 10:42 AM
     We have 2 Aruba 7010 acting as master and local and have configured HA between using the loopback IP addresses.
    When I issue the command show switches all looks good :
    (WLC01) #show switches
    All Switches
    IP Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    10.0.0.100 WLC01 Building1.floor1 master Aruba7010 6.5.0.3_57242 up UPDATE SUCCESSFUL 0 12
    10.0.0.101 WLC02 Building1.floor1 local Aruba7010 6.5.0.3_57242 up UPDATE SUCCESSFUL 1 12
    Total Switches:2
    On the AP database it seems that the AP knows the backup :
    (WLC01) #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    AP1-Indoor default 324 10.0.0.21 Up 2m:15s 2 10.0.0.100 10.0.0.101
    (WLC02) #show ap database
    AP Database
    AP1-Indoor default 324 10.0.0.21 Up 21m:55s 2SI 10.0.0.100 10.0.0.101
    -When I test the HA by taking the cables out from master the AP stays INnactive :
    AP Database
    AP1-Indoor default 324 10.0.0.21 Up 22m:52s 2I 10.0.0.101 10.0.0.100
    Any help on that ?
  • 2.  RE: Aruba 7010 master and local issue with AP HA availability
    Posted Dec 01, 2016 12:05 PM
     Do you have licenses installed on the standby controller ? Are you using Centralize licensing ?
  • 3.  RE: Aruba 7010 master and local issue with AP HA availability
    Posted Dec 02, 2016 01:55 AM
    I am using centralized license the master controller :
    (WLC01) #show license-usage ap
    AP Licenses
    Type Number
    AP Licenses 10
    Overall AP License Limit 10
    AP Usage
    Type Count
    Active CAPs 1
    Standby CAPs 0
    RAPs 0
    Remote-node APs 0
    Tunneled nodes 0
    Total APs 1
    Remaining AP Capacity
    Type Number
    CAPs 9
    RAPs 9
    (WLC02) #show license-usage ap
    AP Licenses
    Type Number
    AP Licenses 7
    Overall AP License Limit 7
    AP Usage
    Type Count
    Active CAPs 0
    Standby CAPs 1
    RAPs 0
    Remote-node APs 0
    Tunneled nodes 0
    Total APs 0
    Type Number
    CAPs 7
    RAPs 7
  • 4.  RE: Aruba 7010 master and local issue with AP HA availability
    Posted Dec 05, 2016 01:55 AM
    It has been solved ,I re-installed the local as master and configured the HA with VRRP .Then I fixed the AAA.
