Aruba 7210 Console small ("phone") cable doesn't work
Hello friends,
I want to use the small ("phone") cable delivered with my Aruba 7210 as a console cable; but it doesn't work. My PC is Windows 10, do i need to install a pilote for it or something special.
Re: Aruba 7210 Console small ("phone") cable doesn't work
Please see the installation guide here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/14423/Default.aspx
