Frequent Contributor II
Aruba 7210 controller port-channel
Hello Airheads,
do you know f you can bundle all 6 ports on a 7210 controller into a 6 port etherchannel.
Thereby making a 6 Gigabit etherchannel (port-channel)
cheers
pete
Occasional Contributor I
Re: Aruba 7210 controller port-channel
Maybe.  You can have up to 8 member ports in a port-channel, but they all must be the same speed.  So if you're running the four SFP+ ports at 10Gb, then you could only have those 4 ports in the port-channel.
thank you for your reply.
we are planning to run all 6 ports @ the same speed yes.
So that would mean the four SFP's running @ 1 gigabit and the
two dual personality ports at 1 gigabit.
hopefully that would be ok?
pete
Yes, you should be fine with that configuration. JJ
#AirheadsMobile
hello JJ,
I Have managed to get a 7210 controller and tried to add the 10 gigabit
ports into a port channel that i already had added the 1 gigabit ports to and i get an error message saying "member 0/0/2 speed doesn't match Pc-1 speed".
hello again,
i am beginning to think it's not an option to have the 2 x 1gigabit ports and the 4 x 10gigabit SFP ports in the same port channel.
Thanks for having a look though appreciate you taking the time JJ.
CHEERS
PETE
Hi Pete, What if you set the speed on the SFP+ ports to 1Gbps first? then try to add to the port-channel? Best, JJ
#AirheadsMobile
pete_elms wrote:
hello again,
CHEERS
PETE
The media in a port channel must be the same..
#AirheadsMobile
You cannot, unfortunately.
Thanks for the confirmation, Colin!
#AirheadsMobile
