Aruba AOS 8.2 : Problem with creating Multizone configuration
Hi All,
There are two questions:
1. How to provision a multizone profile to a particular ap-group in GUI.
2. Through CLI, i have assigned a multizone profile to a particular ap-group named "MD_GRP"q.PNG but that change is not getting replicated in the configuration even after saving the config. i can see only "default" multizone profile in the ap-group " MD_GRP".
PFA for your reference, any help would be much appreciated.
Re: Aruba AOS 8.2 : Problem with creating Multizone configuration
This how-to / guide should help you with configuring MultiZone
https://ase.arubanetworks.com/solutions/id/145
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Super Contributor I
Have you created multi-zone? To check multi zone:
(VMM1) *[mynode] #cd <tab>
/md
/md/LAB
/md/PROD
/mm
/mm/mynode
LAB7005                 Alias for /md/LAB/20:4c:03:03:bb:70
PROD7210                Alias for /md/PROD/00:1a:1e:02:97:d0
<node-path>             Path of config node
If you don’t see any zones here, go to user guide page 354 to configure zone for GUI.
In this case, I have two zones: /md/LAB and /md/PROD. If I want to configure for all controllers under /md/LAB:
(VMM1) *[mynode] #cd /md/LAB
(VMM1) *[LAB] # config t
(VMM1) *[LAB] (config) #ap-group MD_GRP
(VMM1) ^*[LAB] (AP group "MD_GRP") #clone default
(VMM1) ^*[LAB] (AP group "MD_GRP") #exit
(VMM1) ^*[LAB] (config) #write mem
Saving Configuration...
Partial configuration for /md/LAB
Contents of : /flash/ccm/partial/127/p=md=LAB.cfg
[FILE_INFO] /sc 127
ap-group "MD_GRP"
Partial configuration for /md/LAB/20:4c:03:03:bb:70
Contents of : /flash/ccm/partial/127/p=md=LAB=20:4c:03:03:bb:70.cfg
[FILE_INFO] /sc 127
ap-group "MD_GRP"
As you can see, configuration saved to my /LAB and push to controller 20:4c:03:03:bb:70 in /LAB.
~Trinh Nguyen~
Boys Town
Hi
Victor and ngutri thanks for the help.
I have created the multizone profile "zone-1". the problen is that, I am not able to  apply that profile to a particular ap-group.
When ever i apply the multizone profile to a particular  ap-group. the changes dont get reflected in the ap-group config. I have shown the same thing in the above attachent.
even now, the issue is not resolved.
Super Contributor I
From your master, can you run and post:
(VMM1) *[mynode] #show configuration node-hierarchy
~Trinh Nguyen~
Boys Town
