Aruba AOS 8.2 : problem with cluster configurations
Hi All,
I am configuring clustering in aruba AOS 8.2 architecture, So far i have done the config's as prescribed by aruba documentation. the cluster has come up, but when i see the AP details it is not showing the IP of standby controller ...FYI two VMC's are used as controller's. i have attached the screenshot for better understanding...any help wolud be appriciated.
Frequent Contributor I
Re: Aruba AOS 8.2 : problem with cluster configurations
remember I had some issues with this running 8.0.1 i lab on VmWare. I haven't got the VmWare server access here - but something like promiscius mode (or similar) on VmWare networking had to be enbaled to get cluster up-and-running
Hi Jakob_di
Even after enabling the promiscues mode, i was facing this problem..
Hi Jakob_di
FYI, Promiscius mode is enabled in the VM network.
You also have to enable forged transmits.  Have you seen the document here?  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=28637
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
MVP
Console into the AP and reboot it. Break the boot proccess when prompted, and type printenv. Look to see if and what is listed in the nodelist.
Sean Rynearson
Hi Guys
The issue is resolved now, We installed the aruba AOS 8.2 in the 7024 hardwares and the clustering started working fine.
i guess there was some misconfiguration in our VM's, cjoseph and #6938 thanks for help.
MVP
Yes sir. :-)
Sean Rynearson
