Contributor II
Aruba AP 205 Update Question/Help
Last night i worked with Aruba to get my AirWave upgraded to the lateset 8.2.5 from 8.0.10. We didnt get a chance to upgrade the access points and im wondering if the WPA2 issue is related directly to the access points or the AirWave software?
My APs are IAP205 with firmware
ArubaOS (MODEL: 205), Version
what is the lates firmware for the AP's and can i upgrade directly to this firmware or will i need to do like i had to for the AirWave and install other firmware upgrades first before i can download the latest firmware?
