Contributor I
Aruba AP-275
I`ve searched the site and can not find the IP address. Can someone please let me know what is the default  IP address and password for the Aruba AP-275, I`m attempting to configure the unit via web UI as a STAND Alone UNIT any help is appreciated, if theres any additonal information that i may need to configure the unit as stand alone please send that as well.
Kirk
Re: Aruba AP-275
If this is an AP-275 you will need to configure it from a controller. If this is an IAP-275 it will obtain an DHCP IP address from the local LAN it is plugged into. Once the IAP-275 has obtain an IP address you will see the Instant/SetMeUP SSID. The default IAP-275 username and password is "admin"
These videos will walk you through setting up an IAP.
http://www.arubanetworks.com/products/networking/aruba-instant/instant-training/
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Contributor I
Re: Aruba AP-275
Thanks for your reply,
WOW, what are my options? a phyical controller if so can I use the aruba 650 branch office controller? or is there anyway such as a virtual controller for setting up the AP?
Kirk
Re: Aruba AP-275
Yep, if this is an AP-275 you can use a physical controller. The 650 will be able to terminate the AP-275 but will only support up to ArubaOS 6.4.x (in case you need to upgrade in the future...). So maybe a 7005 controller would be a safe bet.
If you wish to configure the 275 series as a standalone AP, then you would need to purchase the IAP-275 model. There is no way to convert the AP-275 into an IAP-275 version.
Contributor I
Re: Aruba AP-275
Thanks for all your help. I Believe its a better option to use the IAP-275 version, I was under the impression I could use the AP-275 as stand alone when I bought the unit.
Kirk
Re: Aruba AP-275
Yeah go with the IAP version. Easier to deploy, no licenses and can be managed via a controller if needed at a later date!
Sent from my iPhone
Contributor I
Re: Aruba AP-275
I received the new IAP-275 its going to be local setup on my mac mini, ive watched the videos on how to setup the unit, how ever i`m having a dificult time setting this AP up i have a solid RED light also im not able to see the SSID that i can connect to configure the unit. pleae help.
Kirk
Re: Aruba AP-275
How are you powering the AP-275?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Aruba AP-275
Which LED is solid red?
Sent from my iPhone
Contributor I
Re: Aruba AP-275
I`m powering the IAP-275 poe, its new out the box, I`m not seeing the setup  SSID to locally configure the unit as stand alone.
Kirk
