Aruba AP 305 factory reset using console
HI all,
How to factory reset AP 305 using console? There is no RJ45 console port at behind of the AP.
thanks
KL
Re: Aruba AP 305 factory reset using console
You do a factory reset with the reset button.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/23249/Default.aspx
Aruba
Or use the console port. For this AP model you'll need an adapter cable: AP-CBL-SER (JW071A).
/Onno
