Aruba AP-315 Configuration Issue
When trying to configure the AP, I follow these steps:
1. Power on the IAP by using an AC adapter. The System Status LED always keeps blinking green.
2. After a couple of minutes, the Radio Status LED keeps blinking green and Instant SSID appears. The System Status LED is still blinking green. I connect to the SSID and try to reach http://instant.arubanetworks.com but the page cannot be reached.
3. Shortly, I get disconnected from the Instant network and Radio Status LED stops blinking. I can still see Instant SSID but I cannot connect to it. Radio Status LED starts blinking again after some time and then stops (this behaviour continues).
Can you please let me know if I am doing something incorrectly? I am following the configuration procedure from Aruba Instant Quick Start Guide.
Re: Aruba AP-315 Configuration Issue
Hey, this is the correct procedure for configuring an IAP. How is the IAP obtaining an IP address, is it via DHCP?
Are you able to ping instant.arubanetworks.com and then connect to the IP address (https://x.x.x.) via https? Also try another browser in case there is a certificate warning preventing you gaining access to the GUI.
It might also be worth attaching a console cable and seeing if there is any messages on the console pertaining to the radio behaviour you are seeing.
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Yes, the AP gets the IP address through DHCP.
I am not able to ping instant.arubanetworks.com
C:\Users\naida.kukuruzovic>ping instant.arubanetworks.com
Pinging instant.arubanetworks.com [169.254.139.173] with 32 bytes of data:
General failure.
General failure.
General failure.
General failure.
Ping statistics for 169.254.139.173:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::943:f317:8616:9b03%3
IPv4 Address. . . . . . . . . . . : 172.31.98.216
Subnet Mask . . . . . . . . . . . : 255.255.254.0
Default Gateway . . . . . . . . . : 172.31.98.1
I tried doing HTTPS do the gateway but I get a certificate warning and after that the page does not load.
I have tried using different browsers.
Unfortunately, I do not have a console cable with the correct connector (4-pin).
To confirm this is an IAP (not AP), you can confirm that by checking the back of the AP and looking at the sticker.
Is the IAP obtaining a DHCP IP address from the local network? If this is the case can you browse to the IAP using a wired connection on the local network using ssh and https?
@NaidaKukuruzovicwrote:
General failure.
General failure.
General failure.
General failure.
The IP address for your wireless client looks good, but is your DHCP server trying to give the IAP a 169.254.0.0/16 IP address? If that's the address that is instant.arubanetworks.com is being translated to, it looks as though the IAP is having problems getting a DHCP assigned address.
If that address range is intended, windows also has problems routing to that network range, which may be complicating your troubleshooting.
Charlie Clemmer
Aruba Customer Engineering
