Aruba AP 315 LED Status Power Green blinking
Hi Everyone
Why Aruba AP 315 LED Status Power Green blinking
Aruba Controller 7210 Version  6.5.0.4
What causes. ?
Re: Aruba AP 315 LED Status Power Green blinking
Hey, if it is the power LED this would suggest the AP is booting? If there is problems with the AP booting, have you tried attaching a console cable and seeing if there is any issues with the AP booting?
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/21953/Default.aspx
AP LED Guide
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
I had the same blinking power LED issue. Once I upgraded the ArubaOS to 6.5.4.3_61959 on the 7010 controller that the APs were pointing to, the blinking power LED became a steady green.
