- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Aruba AP-325 with Extreme K series Switches?
08-02-2017 01:32 PM - edited 08-02-2017 04:10 PM
Hello - anyone else using Aruba AP-325 APs with Extreme (Enterasys) K series switches? Having issues with POE - the APs only sense 802.3af while the switch ports are set to deliver 802.3at (tried auto and manual port configs). Hoping someone else is using similar setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Aruba AP-325 with Extreme K series Switches?
08-02-2017 04:03 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-02-2017 04:09 PM
Yes LLDP is enabled on the ports, and it appears the LLDP negotiation is not working properly (AP says it negotiatied 0.0W and switch port says the requested wattage is 0). So trying to figure out which end is having the issue, the AP or switch. Also seeing differences in the Operational State and Current Hardware State as far as power on the AP depending on what switch we connect to or if we use a mid-span injector. Packet captures are next to see if we can pin-point the LLDP communications, was hoping someone else has been down this road.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
08-11-2017 07:19 AM
For anyone else who may run Extreme K or S series switches with Aruba AP-325 APs, I found the following commands must be run to get the APs to come up to 802.3at power levels:
set port inlinepower *.*.* powerlimit 34000 capability 8023at
set lldp port tx-tlv poe *.*.*
Looks like by default the Extreme switches are set for af power per port
Hope this saves someone else a bit of time and effort when deploying APs
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
