Aruba AP135 connected port has errors
We have deployed Aruba AP135 on a light weight mode with controller 7220US,
We are observing  "input errors" on AP connected port
We have connected the AP to Cisco Modular Switches with WS-X4548-GB-RJ45V  module
All accesspoint were recently deployed with new cabiling .
Same localtion we have teminated AP on a non POE moudle and it works with no errors
I have manually turned off the power inline to access points connected ports , (Power inline Admin state is now OFF and operational status off) still we are getting errors
Re: Aruba AP135 connected port has errors
Check to see if this applies to you here:  https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/ArubaOS-AP-MTU-Support
Colin Joseph
Aruba Customer Engineering
This article was helpful thanks
i have some queries
we have set MTU 1500 on all our switches , how frequently MTU Discovery packets are sent ,
We understand that once the MTU with 1578 fails it drops it to 1500 does the AP again sends the MTU Discovery Pkt to 1578 ?
I got 7000 input errors recorded in last 5 days on AP connected port
