Aruba Airwave Top Header Stats not Client
Help me understand the lack of customer monitoring
Re: Aruba Airwave Top Header Stats not Client
APs\Monitor - screenshot - Aruba - Status UP - all
Are you seeing any actula clients associated to those AP/IAPs in controller/VC?
Are you montioring controller or IAPs? Can you check if AMP Setup>General>Aruba Instant Option>Configuration Only: is set to YES, change to NO.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Yes,
Set to YES
Change to NO and check the status.
Pavan
Pavan
