Frequent Contributor II
Aruba Ap-224 Mesh inquiry?
I just came to know that Each mesh portal will operate for example on 5 GHZ on channel 149 so all mesh point communicating with this mesh portal will also on same channel right?
so what if I have liner mesh like this:
Mesh portal (CH149-->Mesh Point (CH149)-->Mesh Point
so that mean all mesh point  will have the same channel??????
Re: Aruba Ap-224 Mesh inquiry?
Yes.  That is the way they communicate.  They don't always choose channel 149, however.
Colin Joseph
Aruba Customer Engineering
