Aruba Beacon Interval and Power
I am currently testing the Aruba Beacons and I need the TX Power and the Broadcasting Interval of the Beacons for my application, but I could not find this information in any kind of datasheet or help page.
Does anyone know these specifications or where could I look for them?
I am using the beacons in the Location mode.
Re: Aruba Beacon Interval and Power
Carlos,
The datasheet is available here: http://www.arubanetworks.com/products/mobile-engagement/aruba-beacons/
From there, you can see that the beacons chirp at 0 dBm (in location mode, proximity is configurable).
The battery-powered Beacon chirp interval is 500ms long. USB Beacon chirp interval is 100ms long.
Carlos,
In location beacon we can not change the tranmist power level it is fixed. It is hardcored to power level 14 from beacons v.1.8.0 onwards.
Pavan
If my post address your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
