Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
Hello people,
i'm facing this problem..My standalone controller with 4 ap directly connected, they were "down" for an unknow reason and i've commit a Purge command in Campup Whitelist.
Control plane security is disabled.
After reboot, no ap is present (no "up" , no "down" , no under "campus ap whitelist"...)
Checking configuration, now i can see on default vlan there's DHCP = none
This is incorrect! My 4 ap takes ip from network dhcp (...12.101)
Trying to set up it again, but nothing to do! There's ever DHCP = none, also after reboot and writing config
Can u help me please?
aruba 6.0.1.0
thanks!
Nanoweb
Re: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
Can you upgrade the code on your controller to the latest?  6.0.1.0 is much older and could have issues saving the DHCP scope.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
i think upgrading release is really important, but now i can't.
(can u provide a link with detailed information to upgrade release?)
to modify dhcp setting for default vlan, the only way is do CONTROLLER WIZARD?
cannot manually (or by command line) modify dhcp setting for vlan1, is possible?
Thanks..
Thanks..
Yes, you can manually modify the DHCP setting.  On the controller go to Configuration> Network> IP.  There will be a DHCP server tab.
i think there is possible only for other Vlan, no for NATIVE VLAN...
Aruba
To upgrade you have to visit the support.arubanetworks.com site and login with your credentials.
The files will be there to a) upgrade and b) walk you through the procedure to do so (its 5 mouseclicks or less)
Once you have upgraded I would recommend re-tackling this item.
just to clarify are you trying to get DHCP from an external server on your network, or make the controller into a DHCP server for your directly connected APs ?
Hi, thanks for ur time and sorry, I'm in late...
Proble is maybe effect of PURGE command with ap connected for my 4 ap.
Clicking by PURGE button there was a warning , something like "no commit with ap connected!!"
I've clicked same...   :-(
Now i have fear ap are in bad status, so after software upgrade for controller, if problem persist, i need to reset my aps!!
Can i use ethernet cable instead consolle cable to perform a reset?
Where i can find info to perform an ap reset?
M
You can only use the console cable to reset.  Do NOT use the purge command.
Configure your console at 9600, N, 8,1 and plug into the console port of the access point.
Interrupt the boot cycle when it says "press enter...."
At the commandline type "purge" press enter  then type "save" and press enter.
Problem is I've already performed a PURGE command by gui for all my 4 aps!!!!
Until that moment aps get an ip from external dhcp on network
Allright.
After doing that, what is your current problem?
