Aruba Controller 6500 upgrade
Hello Dears,
i want to upgrade my aruba controller. My Aruba controller OS version is 6.3.1.15 .   i see this note in Aruba OS 8.0 sofware download page.
note  is:
ArubaOS 8.0 is a major release and incorporates features which are not compatible with earlier releases. Please review release notes and consult your local Aruba representative before upgrading live production networks. ArubaOS image for 7000 series controllers.Only install if you have a Mobility Master.
if i upgraded my controller which problems will be happen? Whats your suggestion?
Contributor I
Re: Aruba Controller 6500 upgrade
What do you mean with 6500 controller? AOS8 is only supported on 7000, so older generation (do you mean 6000-M3?) doesnt even have the software.
ArubaAz wrote:
Hello Dears,
note  is:
The ArubaOS 8.0 software upgrade completely wipes the configuration of your device, so it is not an upgrade.  It is considerably different from ArubaOS 6.x, so you should have a lab controller to install it on
ArubaAz wrote:
Hello Dears,
note  is:
ArubaAz wrote:
Hello Dears,
note  is:
The ArubaOS 8.0 software upgrade completely wipes the configuration of your existing controller, so it is not an in-place upgrade.  It is considerably different from ArubaOS 6.x, so you should have a lab controller to install it on FIRST before deploying it.
 6000. my controller is 6000 :) sorry
what is the latest version of OS for Aruba6000?
Contributor I
6.4 is the final version for 6000.
