Contributor II
Aruba Controller A7010 Watchdog problem Mad Dog!!
Stage 1 Loader 1.0.5.0 (build 56553)
Built: 2016-09-22 at 05:02:10
Secure Boot Enabled on the Processor
Bank: Secondary Watchdog
CPLD: rev: 3.0 (30:0068|32:0004|33:0000|34:0000|35:0000)
PRID: 000C1203
POWER ON RESET CFG:30CC0FF2
Initialized I2C0 Controller.
Initialized I2C1 Controller.
SPD Rev:0x11 DIMM:0 Type:2 Speed:666MHz #Rank:1
DDR3: Node 0 Channel 0 Mem size = 4096 MB UDIMM
set freq:666666
DDR3: Node 0 DRAM frequency 666 MHz
DDR3: Node 0 CPU frequency 800 MHz
mtb_ps:125 clock:1500 trc:33 trcd:9 trp:9
AP3:A0CFFF0 ODTP1:10000
Board DDR VDD set to 1.5V.
N:0 CH:0 additional rdlvl rdly:1
N:0 Ch:0 m:32 s:32 R OK.
Rank:0 HW WLVL Passed Mask:1FF
n:0 ch:0 RTT WR:0200
===N:0 Ch:0 m:32 s:32 RW OK.
Node:0 Ch:0 TGE Set Memory:4096 MB value:FF FF -- PASS
Node:0 Ch:0 TGE Set Memory:4096 MB value:FF 00 -- PASS
Node:0 Ch:0 TGE Set Memory:4096 MB value:AA 55 -- PASS
Node:0 Ch:0 TGE Set Memory:4096 MB value:00 00 -- PASS
DDR3 Initialization Passed.
NBU0 DRAM BAR0 base: 00000000 limit: 0013f000 xlate: 00000001 node: 00000000 ( 0 MB -> 320 MB, size: 320 MB)
NBU0 DRAM BAR1 base: 001d0000 limit: 00bff000 xlate: 00090001 node: 00000000 ( 464 MB -> 3072 MB, size: 2608 MB)
NBU0 DRAM BAR2 base: 00e00000 limit: 0128f000 xlate: 00290001 node: 00000000 ( 3584 MB -> 4752 MB, size: 1168 MB)
Hit Ctrl + X keys to stop autoboot: 0
CPBoot image is signed
Verifying CPBoot checksum...
CPBoot check passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
## Starting application at 0x8C100000 ...
CPBoot 1.0.7.0 (build 56553)
Built: 2016-09-22 at 04:52:12
DRAM: 4 GB
Detected [XLP208 Rev B1 (Secure Boot) ] (6a|6a)
Flash: 16 MB
Watchdog caused the previous reset. So Running Watchdog Framework
Watchdog reset caused in cpboot context
We even can not step in cpboot, we can go into cpxload only now. What can we do now ? We just upgrade from AOS6.5 to AOS8.2.1 why like this ?
cpxload# help
barinit - barinit
cmp - memory comparing
cp - memory copy
cpboot - execute CPBoot
cpld - cpld : read/write CPLD registers
crc16 - compute crc16
ddr - show ddr registers
ddrinit - ddrinit
ddrrd - read ddr registers
ddrwr - write ddr registers
except - Exception Handler Test
help - print command description/usage
i2c - i2c access
lcm - initialize the LCM
loop - loop cmds
md - memory display
memecc - memecc
memsi - full memory test
mfcr - mfcr: rd registers
mtcr - mtcr: write registers
mtest - memory test
mw - memory write (fill)
phy - show ddr phy registers
phyrd - read ddr phy registers
phywr - write ddr phy registers
printenv- print environment variables
rd - rd registers
rw - write registers
spd - show ddr3 spd data
tge - tge cmds
cpxload#
System will be rebooted in about 1 seconds...
Contributor II
Re: Aruba Controller A7010 Watchdog problem Mad Dog!!
Mad Dog alway reboot , I even can not go into cpboot
DRAM: 4 GB
CPLD: rev: 3.0 (30:8008|32:0004|33:0000|34:0000|35:0000)
Flash: 16 MB
DRAM: 4 GB
Flash: 16 MB
DRAM: 4 GB
Flash: 16 MB
Hi Lin,
If you have the flashbackup available, you can try to check if factory reset option is working from the LCD menu.
Contributor II
are sure the lcd is work without AOS ? We even can not go into cpboot
