Frequent Contributor I
Aruba Controller CLI Command Reference
is there a way to clear the interface counters on an aruba controller?  If so what is the command?
Re: Aruba Controller CLI Command Reference
Looking for the global command, instead of the individual interface.
Aruba
There is no global command you need to do it per port, tunnel, or vrrp interface.
AMFX | ACCX | ACDX | ACMX
Thats what I thought, bummer, thanks for the information...
