Aruba Controller Upgrade
We have a client who is planning to upgrade their Controller 3600 and 3200XM from version 6.4.2.6 to 6.4.3.9. They have AP-92, AP-93, AP-224, AP-225, AP-215 & AP-214 and is wondering if all these AP's supports AOS 6.4.3.9? They can’t find AP support details from Release notes(AOS 6.4.3.9)
Can anyone advise?
Thanks in advance
Re: Aruba Controller Upgrade
Looks like they're all supported. You can check at the following link to see which is the last version an AP or Controller supports: http://www.arubanetworks.com/support-services/end-of-life/
Cheers
James
Cheers
James
Thanks for the document James.
It really helped
